New BMS stage 2 block 4.1 liter on center wet sump not crossed bolted like #153 just 4 bolt main on center two.New BMS stage 2 aluminum heads with valve guides and steel seats.Used set BMS stage 2 aluminum heads with titanium valves,spring and retainers.Used heads come with 42cc chambers.Good condition T&D roller rockers with hardware and shims.BMS forged steel crank 3.625 with standard mains and rods.Crank has never been damaged or repaired.Reconditioned Carrillo 6.5 on center rods with Carr bolts and bushed .927 small rod end.Good used set Comp Cams roller lifters.BMS front timing cover and stock timing cover.Dry sump steel oil pan.BMS on center coverted intake ported to match heads with Felpro 1260 gaskets.New fuel rails with hoses,regulator,90mm elbow and new holley billet throttle body.New complete gasket set, timing chain and Accel DFI sequential box.All of this is beeing sold on Ebay #330132423676.Asking 7,000
