buick v-6 in an s-10
workingdan
My girl freind wants her own toy. I was thinking of putting my spare motor in her 91 s-10. I have most of the parts to install the motoor and trans (200r4) but what would I have to do to wire it all up? Any help would be appreciated.:smile:
Hi,
Get a donor car. If not possible,Painless may be able to help. Or ,ebay sources can pan out.Basically, you are gonna need an engine harness and ECM.It should be a nice fit, though the Buick motor is a bit wider,and has an acute angle to the exhaust ports. Custom headers are probably going to be needed.Lots of work, but I am sure your friend is worth the effort. Good luck!
Caspers sells everything you need for the swap. He can easily make you a harness for the project.
Consider carefully that she may not still be your girlfriend when this project ends and that it could get really awkward. She could be driving her new beau around with your motor! :D
If you're truly devoted to each other, then good luck on the project.
