M
Maxxod73
Guest
Hi everyone.....I am currently building a NA 231 in a 1986 Cutlass and need some suggestions or comments on the following combination....HP guesstimate would be helpful, will the cam/piston combo listed below cause clearence issues? Is there a good combination that would allow me to keep the ECM? and use a CCC carb and the 4.1 intake? I want to make at the least, 200-225 hp. The more the better![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Buick 231 Block Casting # 25526109
Buick Heads Casting # 25518445 ported/polished/port matched/3 angle valve job......w/ 100 lb valve springs
Edelbrock Performer Buick V6 (non-EGR) #5486
NON CCC M4M Rochester Q-jet
Silvolite Buick 3.0L Flat top pistons - 10:1 compression????
Lunati Bracket Master II Camshaft / PN# 00252
Specs: Duration@.050 : 214°
Gross Valve Lift : .472"|.496"
Lobe separation : 112°
MSD 6A Ignition System and HEI coil
NON CC HEI Distributor
Holley/Hooker Headers
w/full 2.5 inch dual exh into 2 chamber Flowmasters
TH-200r4 swapped in place of TH200c
G-Force - 200R4 Racing Crossmember dual hump
2400-2800 stall Torque Converter non-lockup
3.73 gears and PowerTraxx Locker
Thanks for any help
John
Thanks for any help
John
