Hey all - I'm looking for some insight on a Powermaster problem -
since I got the GN out ('87 w/ 48k) this April I felt some feedback or fluttering from the brake petal when stopped – and I see the brake lights are flickering in time with the pulse from the petal. I’ve had good luck with the PM brakes over the past 13 years – I think the only brake part I had to replace was the accumulator.
today I noticed some squeaking (from under the hood) when I used the brakes - the car sat all day after that and when I started it w/ the hood up, some smoke was around the PM right away. I decided to head home carefully (about 6 miles), and the brake light came on as I got home. The part below the master cyl was hot again, w/ burning smell and the brakes weren't there, just started to lose them. I pumped the petal with the car off, and when I started it again, it didn't lower the fluid in the pass. side part of the bowl like I noticed before driving home. I don't think the pump has been running steady, I never noticed the hum from it.
So I'm probably looking at the pump motor and/or switch? Maybe time to change to vacuum - it's just as cheap to do isn't it?
Any thoughts from the experts would be greatly appreciated!
I lost the only mechanic around here who had some GN experience.
__________________
__________________
