My car has a lot of blue smoke at idle. It does not smoke on cold start up, it has to be running for at least a few minutes to start smoking, then it gets worse the more you drive. Sometimes it will come and go, although lately its been doing it more often than not. This is a new motor, with about 200 miles on it. I'm pretty sure the rings have sealed, and if not, I would think my smoking would be more severe under throttle. When I give it boost, it will leave a cloud where I start, then clear out. It mostly does it at idle, and on deceleration, but mainly at idle. I have brand new GN1 heads, suspect the valve guides are bad. I would hope they would not be bad from the get go. Its smoked from day one. No appreciable oil loss. I have no pcv, just breathers. I tried a pcv system, it did not help. All it did was eliminate the smoke from the breathers, which I assume is normal from a car with no pcv. Anyway, the oil looks clean, theres no oil in the up pipe or throttle body. So its not turbo or pcv. That leaves rings or valve guides. Like I said, the rings should be sealed by now, or at least the smoking would be getting better, not worse, if it was rings. Is there anything else it could be? I'm going to look down the runners with the plenum off to see if there a vacuum leak in the intake gasket. Sorry for the long post, just frustrated.
