I am dealing with an issue. I have a C.B. radio in my truck and I am getting some mad static in the radio. I am pretty sure it's in the antenna because there's a buzzing static noise that changes with the rpms of my truck's engine. It doesn't do it when the truck is not running.
Then while in a parking lot, engine off and radio on some guy pulls up next to me to park, the buzzing came into the radio and stopped as soon as the guy shut off his engine. Then when he hit his door locks (electrical) that too came thru the antenna, so i am 99% sure it's coming thru the antenna.
My set up consists of a Uniden PC 66 hard wired directly to the battery (both ground and hot), a Wilson Lil Wil magnet mount antenna and a Rat Shack SWR meter. I have the antenna on top of the truck with the wire ran thru the back window under the seat and up to the radio. It's not near any other wires. My SWR is 1.5:1. The only way to keep the static down is to turn the squelch at about the half mark and keep the RF knob at 3/4.
Would some sort of inline noise filter for the antenna wire be of any benefit? Or do I need to ground the mag mount antenna? What else can I do to eliminate the noise?
Thanks!
Thanks!
