I used a Dremel tool and carefully cut material around the air horn base surrounding the screw until the tip of the Hex screw showed. I then cut a slit on the Hex screw and now all I use is a small screw-driver to adjust the TPS.
*The TPS must sit on the small spring it is for tention.
In order to adjust the TPS off of the car, youl'll have to hook some type of wire line from the top of the TPS male jack on the wire harness to the top of the female jack on the carb and turn the ignition to the on position to get a reading.
The top prong on the male jack is what sends voltage to the TPS. Without voltage, you won't get a reading.
My digital voltmeter I got at Radio Shack. It has a big digital readout screen and is extremely simple to use.
