eastwoodad
- May 23, 2003
I know cam bearings have been discussed quite a bit, but I still seem to have a few questions, so here goes;
I am in the process of rebuilding a 84-85 block. I got the Federal Mogul/SpeedPro rebuild kit and am having the machine shop install the cam bearings. Looking at the front cam bearing, there is a large slotted hole which from reading the Ruggles literature and elsewhere is a bit too big. I don't believe the 84/85 block is grooved and I will have to check to see if my aftermarket cam is grooved.
Here's my thought; can I just have the machine shop rotate the front cam bearing slightly to block some of the slotted portion of the hole or will this create issues? Does there need to be at least a groove in the cam or in the block? Help!!
Thanks,
Aaron
Thanks,
Aaron
