Cam questions?
  • Thread starter Thread starter Cakes
  • Start date Start date
C
Cakes
Guest
I was just wondering if it were too early for a cam in my car with the mods I have. I see a lot of people running the stock cam and doing mostly bolt ons (ie turbos and larger intercoolers). My goal for the future is to run low 11's. Also if its a good idea to go with cam could you give me a suggestion or 2 on what would be a good one for a nice street, daily driver, but a noticable difference in power when I mash the go-pedal. Thanks guys!
The stock Cam will work well down into the 11's. With the kind of torque numbers put up by a stock cam I wouldnt even worry about it unless you are doing a rebuild. Slap a set of ported irons on that beast with the stock cam and you should definately be able to hit your goal of low 11's. If you did decide to put a new cam in there a 206/206 would probably be the best choice for your combo.
