cam sensor problem
gn79
My car will not start. I have check for voltages in the coil and theres nothing. I have check for resistance and it checks out ok. Now I have to check the cam sensor and the box under the coil, I cannot think of the name right now, but to my question now. Can I check for voltage on the cam sensor to see if it is good or not. There is no codes, when its on the car and where. If the cam checks out, then I know what it is.
Wouldnt that more likely be a crank sensor problem before cam sensor?
Crank sensor has more to do with car starting and cam sensor with injector firing sequence, right?
Are you getting spark? Im not sure but if your not getting spark the crank sensor might have something to do with it. Dont remember all the specifics of how the C3I ignition works, but it may be that without a crank position signal no spark will be produced. Or, could be that box under the coil.... also known as the ignition module :rolleyes: :D .
Hopefully someone else will chime in that can verify.
I'm not too sure myself on all the details of how they work, but I DO know that without the cam sensor pluged in that my car will not start. I don't know if that helps but it's my little bit of info.
