Well as I understand it, if you move the cam sensor, you will not affect ignition timing, only fuel timing. You might rortate the cam sensor counterclockwise about 3/16 and see what happens. Almost sounds like a coilpack/ module, or plug wire problem to me though. I'm not the expert here, but have been through some of these same things before. Good luck...Mark
