I saw that Julio had swapped in a 212/212 in his car, but it was 112ls. Is this the hyd. flat tapped from CC?
What difference does the 112LS make against a 110LS?
If You compare the two different camshafts:
Hyd.Flat 260/260adv 212/212 .459/.459lift 112LS
Hyd.Roller 264/264adv 212/212 .504/.504lift 110LS
What would be the benefits of each two?
Thanks in advance
/Andreas
Thanks in advance
/Andreas
