turbojitsu85
- Aug 23, 2002
Car has been running great since the 86/87 ecm conversion exept for some knock and backfire when I get on the pedal no biggy have been trying to work on that one for a while. But today it died on me on the way home from work with a quarter tank of gas and it started to jump around at idle and back fire. I woud be excelerating from a dead stop and it would backfire and try and build boost. It died about three more times until I stopped for gas. After I filled up it started to run normal again. When I first upgraded the injectors it ran great but now it has been running into a lot of problems like the knock and backfire. Any one run into this problem or is my care cursed like I have suspected for years? I should mention that it went threw that quarter tank of gas very quickly if that helps. Not to mention my MPH is like 12/14. After I put the injectors in years ago I could run like 20 pounds of boost with no knock but the turbo would smoke so I set it down to 16. Now I put my foot on the gas and it knocks at like 10. I can't figure it out anymore. Last x-mas I did put a set of MSD 86/87 wires on it because the 10mm ones touched the downpipe. Could these be the problem?
