Chatmanboy
- Jun 25, 2009
SignUp Now!Never seen that before.Also what can cause this? It's on the driver side I would expect this on the passenger side! . . .
I was hoping Chuck would join this thread. . . . . . If anyone knows, he does . . . . you may want to PM him for a solution.OK how do i do that? if you dont mind explaining
Yes, and Yes.Disregard the last message just read what chuck said, going to check it now. Can these injectors be purchased individually?
I've seen several.........They were that way, after being involved in a fire. Jerryl is probably correct.
To check it: Unplug the harness, take your volt ohm meter and check across the pins in the inj. Report back what you get.
Is that a burned wire at the point where the harness is up against the rail?? [Just past the harness boot]
Were you having engine problems, such as a miss, when you found this?
