Can you look at my combo and estimate my times??
Maltman
k...common question I know....but I have to ask :)
and....since I have an everlasting miss (check my other ongoing post for a reference), I haven't been able to make a full pass at wot!
So, I'm wondering if some kind individuals might be able to throw me a bone and tell me what ets or mph I should be looking for .....if I ever fix this miss!!
w/ or w/o slicks?
Thanks,
Mark
P.S. Don't laugh...but if you must know, I was only able to turn out a 13.1 with this current setup....spittin' and sputterin' all the way down at 20lbs of boost(100 octane). Mph was only at 96 because I had to let off!! Makes me want to cry when I look at the price tag for all this crap I put on it! :(
Also, I know my weight is probably a little lower than normal (fiber bumpers, smaller starter....if that makes a difference at all?)
High 11's Shouldn't be a probelm.....my concern is the syclone pump - I don't know if it has the volume to "safely" get you there.
A few of us local guys are planning on going to M7 - shoot me a e-mail if your interested.
You clearly have enough to go 11.40 - 11.50's at about 118-119. I'll second that syclone pump post. Get that thing out of their and replace it with a Walbro 340 and you should be O.K. A V4 or a front mount IC will help you go alot deeper in the 11's but you shouldn't have a problem going mid 11's with what you have right now.
HTH
:cool:
I went 13.2 at 105.6 at the track in Bristol with my mods at the bottom. I ran this with tires that were suppose to be good to 60,000 miles, so I didn't hook up hardly at all. My car also has about 210,000 miles on it. I would think that yours would be a lot faster then mine.
Chris
