i have an annoying miss or hiccup or whatever it is that recently came about at WOT on my car. my car was off the road for about 1.5 months while i saved for a tranny and while it was off i put a eastern perf FM on too. after i got it on the road it had a miss when i was on the car hard so i bought new plugs. the old ones were loose and had a .37 gap which was too big. i gapped them down to .34 since im running 20psi of boost. it seemed to go away and the car was running good but every once in a while it would come back just a tad. well i let it go and it seemed to stop till the other night. car ran great the night before so i turned the FP down 1psi to see if i could lean it a little more. took the car out and it was mising/stuttering at WOT. i put the FP back up 1psi to no avail. as the night went on i was testing stuff out and wehn i got on it one time the IC hose popped right off so i figured get it all on right and i figured out my prob.......wrong. so now i checked the FP it rises with boost, new plugs, 4 month old wires, new coil pack and module, MAF pins 255, all IC hoses tightned down. could putting hte FM on leaned the car out more then i think and thats is causing the stutter. i also have no knock maybe 2 degrees every once in a while when doing it and this is at 20psi. the only thing i noticed is the other night when getting on it the BL was at 105-108 when it used to go to 128?? any ideas would be great guys i dont know why it ran fine and then all of a sudden did this. any ideas on where to look on this it just popped up out of nowhere
