Car runs rough at idle
LookingforaGN
I have a question for you guys just putting this out there. My car is having a hard time staying running when it is cold sometimes it will die out to the point that I have to give it gas to keep it running then after it warms up some it runs like a top and don't have to give it anymore gas just seeing what people think I am thinking that I would check all my temp senors and the IAC senors and see if that is making it run this why when it is cold the car is mostly stock please let me know thanks alot boys:confused:
Thanks, Dan
list any mods done if there are any... stock MAF? stock chip?
if stock MAF unplug it when car is struggling and see if idle clears up. stock chips are not the greatest either in terms of idling.
I will try that out and get back to you I just got the car so I will have to go take a better look at what is done to it and get back to you guys
Thanks, Dan
do you have a scanmaster? if so post the numbers for TPS and IAC if not buy one. its gonna cost you 280ish but its a life saver. there is a plethora of things that could cause bad idle.
