I installed a new coil today and fixed my problem of the car breaking up. I also installed a new Y fitting and hoses and orifice for the turbo.
My BLM is lower, but still high at 139 at idle.
I took it out on the highway at WOT and it shifted through all the gears. This is what I experienced and wonder if there is an answer.
1. Ran smooth, but the boost only goes to 10psi and I am getting .07 KR at the top of third gear. Before I changed the above hoses, I was able to run 13 lbs with 0 KR, any ideas ?
2. At WOT the car shifts at 4100rpms which seems low compared to what the yellow and red lines are on the tach. Any ideas why this is or is there a way to adjust it to shift at a higher RPM ?
I am doing my damndest to learn, I got a long way to go. LOl
Thanks to all that reply.
P.S. The AFPR is set at 42 with vacuum off, the TPS is .42 and the BLM at idle is 139. Car is all stock also.
