NicksTurbo6
- May 25, 2006
OK, car is now running after a year and a half of sitting. Once it start, will only run for 5 to 10 seconds and wants to die. Car ran and drive fine before sitting. It was completely stock. Here is what I did in the downtime:
Racetronix HW kit, Walbo, NOS4GN sending unit
Caspers ground kit, and positive battery kit, heated 02
NGK UR5's gaped at 0.32, MSD wires
T/A race headers, PTE 5857, RJC 3" DP, Cottons 3" cat back
PTE upper plenum with RJC PP
PTE FM IC
Scanmaster, AEM WB
I still have the stock chip, injectors, and MAF in the car. I have a Turbo Tweak chip, 60's, Translator, and Z06 MAF waiting to go in. I wanted to get the car running first on the stock stuff before going further. The car starts and runs for a few seconds, then it wants to die like its not getting enough fuel. If I tap the gas a few times, I can keep it running, but its not smooth. I have an AEM WB hooked up, and you can see the gauge start off around 14:1 AFR, then go leaner like 15...16...17..18 then according to the WB it goes so lean its off the gauge. If I give it some gas, it will bounce down for a second to around 15 or 16:1, then back to super lean where it wants to sputter and die. I checked everywhere for vacuum leaks and cant find or hear anything. I had an oil pump prime issue where I pulled the cam sensor out to prime the system. I Reinstalled the cam sensor, and set it using Casper's Cam setting tool. I triple checked it, and that's all good too. One thing I will check later is fuel pressure and verify it with a gauge. Other than that, I don't know what else it could be. Any suggestions?
Nick
PTE FM IC
Scanmaster, AEM WB
Nick
