This concerns a gov. surplus '83 Chevy Malibu sedan, with the famous "VIN A" Buick V6 (NA with a humongous computer controlled DualJet carb).
First there was a dead ISC nose switch. To compensate, someone had adjusted both the idle stop screw and the ISC plunger to "hardwire" curb idle at 650 RPM.
Once the nose switch was fixed, there was a time of good idle-downs. The car went from full-choke fast idle to curb idle in nice, regular steps untouched by human hands (well, OK, so rough the car shook like a cement mixer).
Then I had to replace the intake manifold, as the flange for the Torx bolt hidden under the distributor was discovered to be, uh, not there. (None of the bolts offered much resistance to removal, so I guess the intake must have flexed too much. The crankcase was having carbon pumped into it, but no coolant.)
Since the manifold was replaced, the car has not idled down, period. I have to kick the accelerator to get it to move down each step, and then it's very balky about going to curb idle. It doesn't want to go to curb idle after driving, either, but it will if I kick the accelerator enough.
The choke opens normally, but the throttle doesn't want to close. The ISC is working fine, everything seems to have good freedom of movement, the return springs are both fine, the accelerator and pump both work normally. The choke coil and vacuum breaks all work fine.
Now, I know what you'll say: "Squirt carb cleaner on it and it'll work fine." It's off the car, but I did just spray it and can't tell any difference. And even if somehow now it will work, HOW and WHY will it work?!?
I've NEVER understood how the fast idle cam is supposed to move down. I have a 1980 DualJet manual that says:
"The fast idle cam has graduated steps so that the fast idle speed is lowered gradually during the engine warm-up period. The fast idle cam movement (and step position) is a function of choke valve position."
Unfortunately, it doesn't explain HOW it's a function of choke position. There isn't any detailed mechanical theory of operation for the fast idle cam.
From what I see, the fast idle cam is passive, that is, the intermediate choke shaft forces it up where the cam follower lands on the high step. But from there, nothing forces it to follow the intermediate choke shaft as the choke opens, and the cam follower actually PREVENTS it from moving, far from forcing it to move. I can get it to click nicely down the steps by pushing on it lightly with my finger.
And this is no different than back in the days when it actually worked.
What empowers the voodoo economics of choke idle-down?
-- Jim Howard <jiho@c-zone.net>
