carfax please!
gmpower
can somebody please helpme with carfax?
vin# 1g4gk4778gp432884
also can you tell from the vin if it is a true 1986 GN?
thank you.
1986 BUICK REGAL T-TYPE
1G4GK4778GP432884
COUPE
3.8L V6 SFI OHV / REAR WHEEL DRIVE
Standard Equipment | Safety Options
Hi-I'm the CARFAX Xpert™. I'm here to help you better understand the data in this CARFAX Report. Did you know...
We checked over 5 billion records from thousands of data sources for this vehicle
This vehicle DOES NOT qualify for the CARFAX Buyback Guarantee
The last reported odometer reading was 74,081
A CARFAX Vehicle History Report is based only on information supplied to CARFAX. Other information about this vehicle, including problems, may not have been reported to CARFAX. Use this report as one important tool, along with a vehicle inspection and test drive, to make a better decision about your next used car.
CARFAX guarantees the information in this section
Salvage | Junk | Rebuilt No Problem
Fire/Flood | Hail Damage | Buyback/Lemon No Problem
Not Actual Mileage | Exceeds Mechanical Limits
Alert!
Problem Found
Alert! Severe problems were reported by a state Department of Motor Vehicles (DMV). This vehicle does not qualify for the CARFAX Buyback Guarantee.
Not all accidents or other issues are reported to CARFAX
Total Loss Check
No total loss reported to CARFAX. No Issues Reported
Structural / Frame Damage Check
No structural / frame damage reported to CARFAX. No Issues Reported
Airbag Deployment Check
No airbag deployment reported to CARFAX. No Issues Reported
Odometer Rollback Check
See State DMV-reported Title Problems above. Inconsistent odometer reading indicated. Alert!
Problem Found
Accident Check
No accidents reported to CARFAX. No Issues Reported
Manufacturer Recall Check
Check with an authorized Buick dealer for any open recalls. No Recalls Reported
Basic Warranty Check
No data reported to CARFAX.
No Data Reported
Tell us what you know about this vehicle
Looking for other 1986 BUICK REGAL vehicles like this one in your area?
Search CARFAX Hot Listings for an up-to-date list of vehicles in your area, all with the CARFAX Buyback Guarantee!
A CARFAX Vehicle History Report is based only on information supplied to CARFAX. CARFAX checked over 5 billion vehicle history events and found 16 record(s) for this 1986 BUICK REGAL T-TYPE (1G4GK4778GP432884).
Date: Mileage: Source: Comments:
04/18/1992 80,852 California
Inspection Station
Los Altos, CA Passed emissions inspection
05/06/1994 8,499 California
Inspection Station
INCONSISTENT ODOMETER READING
Hmmm...hard to tell whether this reading represents an odometer rollback or a clerical error. Confirm the mileage with your dealer or qualified mechanic.
04/17/1998 31,418 California
Inspection Station
01/19/1999 125,000 California
Motor Vehicle Dept. Odometer reading reported for title
or registration
01/22/1999 California
Motor Vehicle Dept. Title issued or updated
New owner reported
01/29/2000 48,918 California
Inspection Station
North Hollywood, CA Passed emissions inspection
03/19/2000 California
Motor Vehicle Dept.
Los Angeles, CA EXCEEDS MECHANICAL LIMITS TITLE ISSUED
CARFAX Advisor™
An EML title is issued when the owner discloses an odometer rollover to a DMV. Rollovers occur on vehicles with 5-digit odometers that go from 99,999 to 00,000 every 100,000 miles.
Mileage reported after this reading is potentially unreliable.
12/06/2000 52,097 California
Inspection Station
Montebello, CA Failed emissions inspection
Designated GROSS POLLUTER
12/06/2000 52,094 California
Inspection Station
12/11/2000 52,279 California
Inspection Station
Pasadena, CA Passed emissions inspection
12/11/2000 52,296 California
Inspection Station
Covina, CA Passed emissions inspection
03/24/2002 68,357 California
Inspection Station
Covina, CA Failed emissions inspection
10/17/2002 69,971 California
Inspection Station
Rosemead, CA Passed emissions inspection
02/01/2004 California
Motor Vehicle Dept.
Rosemead, CA Title issued or updated
New owner reported
07/08/2005 74,081 California
Inspection Station
Torrance, CA Passed emissions inspection
07/11/2005 California
Motor Vehicle Dept.
Huntington Park, CA Title issued or updated
New owner reported
CARFAX used car VIN number search, auto history check, vehicle history reports
A vehicle with a 5-digit odometer cannot accurately track mileage after 99,999 miles because the odometer rolls over. This title is the result of a seller certifying under the Federal Odometer Act, that the odometer reading EXCEEDS MECHANICAL LIMITS of the odometer.
Failed Emissions Inspection
The emissions check performed during a vehicle inspection indicated the vehicle was emitting more than allowable emissions standards and/or had missing or modified parts. Repeated failed emissions records can indicate engine problems and CARFAX recommends you have the vehicle inspected.
The Federal Odometer Act requires a seller to disclose the vehicle's mileage on the title when ownership is transferred. Congress enacted this Act to prohibit odometer tampering and to protect consumers from mileage fraud. Under this act, sellers must disclose any issues with the vehicle's odometer. These disclosures translate into the Exceed Mechanical Limits and Not Actual Mileage titles.
Gross Polluter
A Gross Polluter is a vehicle that fails an emissions inspection with below-standard scores. These vehicles can pollute as much as 18 times more than a vehicle that passes an emissions inspection. It is illegal to drive or sell a gross polluting vehicle in California, and it cannot be registered with the DMV. CARFAX recommends checking the latest Vehicle Inspection Report to confirm the proper repairs have been completed before purchasing.
Mileage Inconsistency
If a more recent odometer reading is less than an older reading but CARFAX is uncertain whether the discrepancy is a rollback or a clerical error, then CARFAX calls it a "Mileage Inconsistency". In this case, you should verify the mileage with your dealer or a qualified mechanic.
New Owner Reported
When a vehicle is sold to a new owner, the Title must be transferred to the new owner(s) at a Department of Motor Vehicles.
Ownership History
CARFAX defines an owner as an individual or business that possesses and uses a vehicle. Not all title transactions represent changes in ownership. To provide estimated number of owners, CARFAX proprietary technology analyzes all the events in a vehicle history. Estimated ownership is available for vehicles manufactured after 1994 and titled solely in the US including Puerto Rico. Dealers sometimes opt to take ownership of a vehicle and are required to in the following states: Maine, Massachusetts, New Jersey, Ohio, Oklahoma, Pennsylvania and South Dakota. Please consider this as you review a vehicle's estimated ownership history.
Title Issued
A state issues a title to provide a vehicle owner with proof of ownership. Each title has a unique number. Each title or registration record on a CARFAX report does not necessarily indicate a change in ownership. In Canada, a registration and bill of sale are used as proof of ownership.
Additional Services & Resources
Auto Loans - LendingTree InsWeb Auto Insurance Extended Warranty
CARFAX DEPENDS ON ITS SOURCES FOR THE ACCURACY AND RELIABILITY OF ITS INFORMATION. THEREFORE, NO RESPONSIBILITY IS ASSUMED BY CARFAX OR ITS AGENTS FOR ERRORS OR OMISSIONS IN THIS REPORT. CARFAX FURTHER EXPRESSLY DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. CARFAX®
© 2007 CARFAX, Inc., an R.L. Polk & Co. company. All rights reserved. Patents pending. 28.Oct.2007 07:30:21
Accident Indicator
Various events could indicate an accident in a vehicle's history, such as: salvage auction, fire damage, police-reported accident, crash test vehicle, damage disclosure, collision repair facility and automotive recycler records. See the glossary for more information.Airbag Deployment
Occurs when the driver, passenger or side airbag has been used or deployed during a crash or other incident. If an airbag has been deployed, it must be replaced by a qualified technician. Have this car inspected by a mechanic prior to purchase.Total Loss
An insurance or fleet company declares a vehicle a total loss when a claim exceeds ~ 75% of its pre-damage value or if the vehicle is stolen and not recovered. This damage threshold varies by company. These companies typically take possession and obtain the title. Not all total loss vehicles result in a DMV-reported branded title, like a Salvage or Junk title. See the glossary for more information.Structural / Frame Damage
In most cases, a vehicle is inspected for structural or frame damage, depending on the body design, after an accident or other incident. All levels of accidents from minor to severe can cause structural / frame damage and in most cases it can be repaired. Odometer Rollback
If a more recent odometer reading is less than an older reading, then the odometer may have been tampered with and "rolled back".Manufacturer Recall
Automobile manufacturers issue recall notices to inform owners of car defects that have come to the manufacturer's attention. Recalls also suggest improvements that can be made to improve the safety of a particular vehicle. Most manufacturer recalls can be repaired at no cost to you.Basic Warranty
Most manufacturers offer a basic warranty for new vehicles. These warranties vary by manufacturer and typically last for a certain amount of time and/or a set number of miles.Salvage Title
A Salvage Title is issued on a vehicle damaged to the extent that the cost of repairing the vehicle exceeds ~ 75% of its pre-damage value. This damage threshold may vary by state. Some states treat Junk titles the same as Salvage but the majority use this title to indicate that a vehicle is not road worthy and cannot be titled again in that state. The following ten States also use Salvage titles to identify stolen vehicles - AZ, FL, GA, IL, MD, MN, NJ, NM, NY, OK and OR.Junk Title
A Junk Title is issued on a vehicle damaged to the extent that the cost of repairing the vehicle exceeds ~ 75% of its pre-damage value. This damage threshold may vary by state. The majority of states use this title to indicate that a vehicle is not road worthy and cannot be titled again. Some states treat Junk titles the same as Salvage.Rebuilt/Reconstructed Title
A Rebuilt/Reconstructed vehicle is a salvage vehicle that has been repaired and restored to operation. These vehicles are often severely damaged before they are rebuilt and refurbished parts are typically used during reconstruction. In most states, an inspection of the vehicle is required before the vehicle is allowed to return to the road. Loss Due To Fire Title
The vehicle sustained major damage due to fire. In most states, fire damage titles are issued when the cost of repairing the vehicle for safe operation exceeds its fair market value.Flood Damage Title
States issue flood titles when a vehicle has been in a flood or has received extensive water damage. Hail Damage Title
The vehicle sustained major damage due to hail. In most states, hail damage titles are issued when the cost of repairing the vehicle for safe operation exceeds its fair market value.Manufacturer Buyback or Lemon
A DMV or a state agency marks an official document or issues a Manufacturer Buyback/Lemon title when a vehicle has been repurchased by the manufacturer. Not all states issue manufacturer buyback titles and the specific requirements for a lemon law vehicle varies by state.Not Actual Mileage Title
When the seller certifies, under the Federal Odometer Act, that the odometer reading does not reflect the vehicle's actual mileage. This may occur because the odometer was tampered with, broken, or replaced.Exceeds Mechanical Limits
A vehicle with a 5-digit odometer cannot accurately track mileage after 99,999 miles because the odometer rolls over. This title is the result of a seller certifying under the Federal Odometer Act, that the odometer reading EXCEEDS MECHANICAL LIMITS of the odometer.Standard Equipment
Power Steering, Air Conditioning, AM, Power Brakes, 6-digit Odometer Safety Options
Active (manual) belts
Thank you very much, GTEATR6!... I did look at that 86, and I passed. However, I went to look at another 86 2 weeks later, and bought it:cool:
