Caspers Fuel Pump Wiring Upgrade 84/87
tbirdv6
Its a known fact that a weak link in tuning your Turbo Buick is the inadequate fuel pump feed wire. When you install a higher capacity fuel pump, you place a greater demand on the wiring to the pump. Voltage drop in excess of 2 volts have been observed due to the factory's wiring being unable to pass sufficient current to the pump. Our *plug-and-play* kit remedies this problem by supplying a larger gauge wire to the pump. NO WIRES TO CUT! Includes SEALED relay, SEALED fuse holder and all OEM style wiring and connectors.
The above info from Caspers website
Used,but in great condition,no bad plugs or cut wires
$35 shipped in USA
paypal accept, acct = turbobuick4@yahoo.com
FRED
I will take the hotwire kit for 30.00 shipped if that sounds good to you I will get you a money order sent out Thank's
I had someone email me for $35 shipped, if the sale falls thru,I'll let you know,
FRED
