TurboJoe3.8
Senior Member
- Feb 19, 2003
Still in the original box with the instructions
Here is the description taken from Caspers website:
TPS voltage at Wide-Open Throttle (WOT) is a function of power enrichment (PE). If the voltage is below a certain point at WOT, the ECM will reduce the level of power enrichment and the engine will not perform to its potential. This device is completely transparent until 70% TPS, then it takes over and assures maximum TPS voltage for 100% Power Enrichment (PE) when you need it the most. The TPS TEC also corrects for low sensor voltage and "dead spots" and uses a bank of LED's to accurately set the TPS sensor for proper idle.
Price is $45.00 shipped- Paypal accepted
Sells new for $90.00
Thanks!
Thanks!
