Freddie's Buick
Hell No! I'm not a junior
- Jan 3, 2002
Guys,
Correct me if I'm wrong please....
The THERMAC system is for 'controlled' induction of warm air for cold engine operation emissions.
If one hooks up a cold air induction system on our cars, then this defeats the OEM purpose which is highly restrictive. My verdict is if you want power, get rid of the OEM system. It will increase performance.
*(If the state one lives in does emissions control testing, leave it alone and don't do any of the following comments I write about).
The A.I.R. Pump system is also for cold engine operation emissions. In addition to this it works in conjunction with the Cat Converter during decelleration emissions. If one removes the Cat, then this renders the pump useless. Why keep the air pump system then? Get rid of it!
The EGR system is unique to the vehicles configuration. It works on and off during warm engine temperatures only. My verdict on this is still a cautious null.
The EFE system is also for rapid warming of the engine during cold engine operation. Our cars use two differant types. The electric type is not restrictive. It is beneficial.
Even the vacuum type is beneficial for quick warm up. (Though highly restrictive). Removing the vacuum type would cause a car from up north to take a longer time to warm up. This is up to an individual's taste if is to be removed.
In my opinion the only true beneficial emissions control system on our cars is the EECS system. IT SAVES GAS! It does not impede performance. And it is easy to maintain and rarely needs maintenance. This makes it a champion! Leave it alone!
