SignUp Now!they are off of a champion racing intake not really only thing i need are 325 50 15 drag radialsWhat do the rails fit? Want to trade for anything?
nowould you sell the lines and fittings from the fuel rail alone.?
So will not fit a stock intake manifold?they are off of a champion racing intake not really only thing i need are 325 50 15 drag radials
They don't fit on a stock intake mark..So will not fit a stock intake manifold?
regulator mounts in the stock locationInterested in trading the rails for the Champion rails designed for an external regulator.
the injector holes all line up but you would have to do some mods on the mountingSo will not fit a stock intake manifold?
no thanks im just running stock fuel railsInterested in trading the rails for the Champion rails designed for an external regulator.
TTTno thanks im just running stock fuel rails
they came off a champion race intake, not a stock intake that was ported from champion what do you have ?I'm a little confused about what these fuel rails will fit. I have a Champion intake on my stock block, but didn't know Champion did anything to the intake whee the factory rail mounts. I an using the stock fuel rail currently. So will this rail fit? If so, I am interested!
Eric I have the stock style Champion CNC ported intake.[/quote i have a stock intake i tryed the fuel rail on the mounting on rail would have to be modified it fit the stock intake, regulator is a oring 2 bolt mount
