Champion ported intake
cooled85T
Empty Pockets
Champion ported intake and doghouse. Powdercoated silver. Stock throttle body with vacuum ports relocated to back of intake. Iac angled port. Kenne bell regulator. Stock fuel rail. Rjc power plate. Air temp sensor port welded into doghouse. Egr delete. Complete bolt on setup. Was saving for my spare motor but need some cash for current setup. $700 obo. Will split up if I get buyers for the separate pieces.
Do you have any more pics of the back of the intake? Does the coil pack clear all those vacuum fittings?
I'll have to get some when I get home. I can't imagine they wouldn't clear the coil mount being they are under the doghouse. They could also be plugged if they weren't wanted. It's just tapped standard pipe thread
