Charleston/Lowcountry Grand Nationals
DGC
Senior Member
looking for an 'ignition only on' hot lead in the engine compartment. already used the two brn leads to the powermaster connectors (removed powermaster a while ago)
for other items. Red leads to coolant fan delay relays are always hot. i would rather use an ignition only hot lead, but i do not want to fish under the dash, or pull
a wire from the radio (removed).
suggestions would be helpful.
thanks
dgc
the emmission cannsiter plug pink/blk strip and the same on the boost solenoid and egr solenoid are switched 12v
pacecarta,
thanks a bunch. i have thumbed through the 2 volume shop manual looking for this page. where did you find it??
dgc
