Checking for leaks with new injectors
BFlat
I’ll be replacing injectors & other top engine parts. Ignition module, throttle body/IAC/vacuum block hoses will be removed. Can I install just the new injectors, fuel rail & injector wiring harness and fuel lines and then turn the key (not start) to have the fuel pump kick in to check for leaks without re-installing all the other stuff?
Kind of an old post but if you mean installing the injectors in the fuel rail but not seated in the intake manifold, then those injectors will come flying out of the fuel rail as soon as it comes up on pressure...if you aren't still using the factory clips that help retain the injectors. If you don't have the factory clips anymore, you can use zip ties to hold them on the fuel rail. Did this a few times over the years to check for leaking injectors.
