Chip And Alky
ttypenssrider
Stock Chip Ok To Use With Alky On Stock Turbo Regal??
Maybe Just An K&n Filter And Open Exhaust.
Any One Have Any Experiences With This??
There is actually a lot of information on this topic..
But since you will be running Alky and timing needs to be increased plus a few other things you would want to get an alky chip. Also after doing some research you will see that everybody well almost everybody loves the TurboTweak chip. which I can tell you first hand is an amazing chip.
Go to TurboTweak and check the 91/94 alky chip to see how it is configured. you will need to supply your cars exact setup though when ordering.
Stock chip... bad for this.
You'll need an aftermarket chip, updated fuel pump, adj fuel pressure regulator, a scantool to monitor knock, and an engine running in proper order.
ok ill look into his chip.
i have a scanmaster and a walboro fuel pump kit from racetronix but not a regulator yet.i thought it wasnt needed for stock injectors.
If I remember correctly a stock chip has 24d of timing and so does a typical TT alky chip. Eric puts a timing delay into his chips. Timing is trimmed back to 18-20d for a sec or so until the alky sprays and then go back to 24d. Its sweet.
