CK Shift kit "RED" 1-2 accumulator spring
gusszgs
If anyone out there has purchased a CK shift kit and DID NOT use the "red" 1-2 accumulator spring from their kit, I need one.
The red spring was discontinued in favor of blue spring to shim acc piston.What are you trying to accomplish?
As per instructions I received through e-mail......it says to use the tall red 1-2 accumulator spring if over a certian hp level (400hp). I did not get that spring in my kit.....nor did I get a blue shim spring.
It says to use the white 1-2 accumulator spring if less than 400hp and using a 12" converter.
I'll be using a 10" PTC converter and your billet servo, so I assumed I should be using the "red" spring.
