Rob_85Ttype
- May 26, 2001
All prices plus shipping. Please provide for Paypal fees by adding either 3% or friends and family.
________________________________________________
The following parts are still available
86-87 TPS new AC-Delco $50
86-87 IAC new AC-Delco with mount $40
86-87 Turbo J bracket $40
86-87 Coolant lines $25
86-87 Pass valve cover filter heat shield $15
84-87 EGR cover $10
84-85 Mass airflow sensor 35000 miles OEM $40
84-85 IAC used no mount 35000 miles OEM (not pictured) $20
84-87 Brass oil pressure feed block (not pictured, for turbo) $20
84-85 wastegate solenoid (not pictured) 35000 miles OEM $25
84-85 EGR solenoid (not pictured) 35000 miles OEM $20
84-85 MAF (not pictured) 35000 miles OEM $40
Remote fuel gauge for use with stock fuel rail - new (connects directly to the shraeder valve location on the fuel rail and lays on the fender well near the cruise control solenoid) $40
The following parts are SOLD
Accessory bracket with fasteners $75 -- SOLD
Intercooler bracket: $25 -- SOLD
Rear L bracket for AC support $20 -- SOLD
Coil support bracket $25 -- SOLD
Accelerator cable bracket $25 -- SOLD
86-87 WP pulley (not pictured) $25 -- SOLD
86-87 PS pulley (not pictured) $20 -- SOLD
Tensioner new bearing $135 -- SOLD
Turbo shield cut for 3” TH style DP $50 -- SOLD
Vacuum lines $40 set or $20 each -- SOLD
Rear Y bracket alternator/AC support $25 -- SOLD
Front Y bracket alternator/AC support $25 -- SOLD
Turbo oil return $25 -- SOLD
Fuel rail (84-85) but works with 86-87 plenum and manifold - missing internal shraeder valve components $35 -- SOLD
Accufab fuel pressure regulator new $100 -- SOLD
Newly remanufactured Cardone power steering pump (all new internals - only the pump housing is reused) $60 -- SOLD
84-87 EGR cover $10
