Cleaning out the Garage (Parts for Sale)
wiseman
Hello Everyone,
The wife is on me about cleaning out the garage and I need to sale \ get rid of some old GN parts or trash them. Here are some pics for the items I have left or removed from my GN Build. I am not trying to get rich, mostly just hate to trash some of this stuff since the parts are salvageable to use on another car , but require some refurbishing. I am flexible on some prices and shipping is not included. PM or message me for any additional pics if needed, thanks!
$15 for Turbo Inlet Bell ----- SOLD
$20 for Power Switch & Lock Set (i was having problems with 1 of the Lock Switches) --- (******Available******)
$35 for Header Set (Driver Side needs Welding) --- SOLD
$20 for each Pulley --- (******Available******)
$20 for Throttle Body --- (******Available******)
$20 for Set of Injectors --- (******Available******)
$20 for Set of 3 Wheel Caps --- SOLD
$15 for Hood Hinges (Set) --- SOLD
$20 for Air Dam Set (Needs "Back to Black Polishing") ---- SOLD
$25 each for Front Or Rear Bumper Cushion --- SOLD (Front)
$15 each for Headlight Bezel (They were painted by previous owner, Need of sanding and painting) --- (******Available******)
$20 for Floor Pan Set--- (******Available******)
$75 for Aftermarket Header Set (Chinese Made) --- SOLD
$10 for Coolant Bottle or Washer Fluid Bottle (Needs Cleaning) --- (******Available******)
$50 for Stock Turbo --- (******Available******)
$30 set for Door Sill Set (Needs some polishing) --- (******Available******)
$50 Rear Seat Pad Set --- (******Available******)
$20 Front Set Pad Set --- (******Available******)
Interested in the seat pads and front bezels
Shipped to 00969
$10 for Pair of Rear Seat Side Wall Panel --- (******Available******)
$ 15 for Pair of Head Rest --- SOLD
$30 for Condensor - Shows Corrosion in pics but was working perfectly when removed/ NO leaks) --- (******Available******)
$30 for Radiator - Shows Corrosion in pics but was working perfectly when removed/ NO leaks) --- (******Available******)
Here is what I will take after the above persons in line.
$15 for Turbo Inlet Bell SOLD?
$35 for Header Set (Driver Side needs Welding) SOLD?
$20 for each Pulley
$20 for Set of 2 Wheel Caps
$20 for Air Dam Set (Needs "Back to Black Polishing") SOLD?
$15 each for Headlight Bezel (They were painted by previous owner, Need of sanding and painting) SOLD?
$75 for Aftermarket Header Set (Chinese Made) No miles on them, bought for temp, use
while building engine up. SOLD?
$50 for Stock Turbo
$50 Rear Seat Pad Set SOLD?
$20 Front Set Pad Set SOLD?
$ 15 for Pair of Head Rest $30 for Condensor - Shows Corrosion in pics but was working perfectly when removed/ NO leaks)
$20 for each Pulley
$50 for Stock Turbo
Put me in line after this kool guy!:p
86 buick w11/cc1
U people are like hungry pigs!!!
Headliner - $80 plus $30 shipping: ---- SOLD
I have a new headliner for sale. It was purchased for an 86 GN with a map light (the map light cutout has not been cut). I put 2 small holes in it for the dome light studs. It was brand new i installed it and cut the holes. There was a manufacturer defect where the fabric isn't glued extremely perfect in a spot. It can be installed as is without any issues with a dome light. But if the spot bothers you, u can recover it with no problems. It is made of ABS material, so it can be recovered with any type of material if you want to replace your old original headliner.
Here are some additional pics of the headliner out of the car (waiting for its new owner :) )
Red - 2 holes I drilled for the dome light option. It does have the map light cutout also (board is cut, fabric not cut)
Orange - Minor defect from vendor (barely noticeable)
Green - Defect from vendor (noticeable)
Selling for $80, but shipping will be $30. (Large box)
Here is original post couple months back:
http://www.turbobuick.com/forums/threads/new-headliner-for-sale.386170/#post-3110838
Well if they are still available I'll take the Throttle Body, hood hinges, either pulley that's available.
I guess I'm in line with the other Crackheads!!
I also just remembered to post this also. I purchased a CK Performance transmission Recalibration/shift kit earlier this year. I used the cork gasket, but I can include a rubber gasket that I have in the kit.
Recalibration Kit - $85 plus shipping
I have pictures, but for some reason they won't upload from my iPad.
