clear coat
mybuick
intercooled engines rule!
well i learned the hard way not to wet sand the paint, because i go through a coat of paint then i get black spots... so i will put another coat of paint on the car, and with all the orange peel if i clear the car and all the orange peel is in the color will it show through the clear after i wet sand the clear. i plan to put 4 coats of clear on the paint and sand through 1 or 2.
Need more information. When you painted your car. Did you base/clear or single stage? Sence you have already gone through. You need to go ahead and sand the orange peal all the way out of the entire car. Then go back with base at least over the areas that you went through a couple of coats. Then just give the whole car a quick coat of base and then clear it. Remember the smoother the finish (clear) the easier it will be to color sand and better it will look after its done.
