CODE 44
Trouble Code 44 indicates that the O2 sensor is showing a persistently high exhaust oxygen content (lean), despite the efforts of the ECM to increase injector on-time (thus increasing fuel delivered). Integrator and BLM numbers may indicate > 128 by a substantial margin.
The conditions for setting this code are:
no Code 33 or Code 34 (MAF Error) present, and
the O2 sensor voltage remains below 250 mVolts, and
the ECM is in Closed Loop control, and
the above conditions exist for more than 50 seconds.
Typical causes for this code include:
1) O2 sensor defective or lead shorted
2) Lean injectors (dirty or blocked)
3) Water in fuel
4) Exhaust leaks upstream of O2 sensor
5) Fuel pressure or volume too low
6) MAF sensor reading lower airflow than is actually present
7) Vacuum leaks
8) Incorrect or poorly calibrated PROM
It's thrown the code three times now. All three times the car was idling for a minute or so.
I replaced the o2 sensor today (used the GNX one, Delco part #25162753).
It sounds like I have an exhaust leak. Since it wasn't the o2 sensor I'm assuming the exhaust leak would be the cause?
How much does an exhaust leak effect idle? It really idles like crap.
What's the best way of tracking down an exhaust leak? Normal places to look (sounds like its coming from the passenger side)?
TIA.
