ProchargedCobra
- Jan 24, 2002
I did a couple of searches and could not find anything on this.
Once the car is warm I set the VE tables to get the desired idle characteristics. The car idles best around 12.5-13.0 : 1.
Then the next day when the car is cold, it is extremely rich, like 10:1 on initial startup. Progressivly leans up as car warms up/
There AE fuel vs. CTS has no enrichment at the startup temp, and the same thing goes for the CTS.
Any thoughts on this. Is there anywhere else I could take out fuel enrichment based on coolant temp, or heat soak.
If I set the ve tables to idle at a decent a/f when cold, then when it gets warm (heat soaked) it is very lean (14:1) and does not idle well that lean.
