Colors?
BoostedDeuce
What color is methanol? alcohol? I thought they were both clear? but I picked up some "methanol" lastnight and it is blue.. idunno... anyone have any ideas?
Has lube or you picked up windshield washer fluid :mad:
The meth I have been running I buy from a local auto shop. The owner has an Car that runs Alky. This is also a light blue. I assume that is the lube as you mentioned Julio. Is that ok? Thanks,
Matthew
Should be ok.. the issue is I havent tested the pump for extended periods using the lube added. The alcohol I get down here at all my distributors is clear.
And.... When lube is added, my understanding is they add very little.
I need to get some of that bubble gum smell lube :D
