Converting program
J-B Racing
Forced Induction
If I have a program for my FAST and itès set up for Distributor..is their a method to switch over to the DIS?
Or not possible..
Nothing really to change. Just make sure the Crank Referance Angle is correct (it shouldn't change). If it's an XFI make sure you have DIS selected. It should already be that, unless you have moved the reluctor on the balancer. If the reluctor has been moved, you will need to move it back. Like I said, you shouldn't have to change anything.
Cal,
I have the Classic FAST box.
