Note: Engine out and on stand.
Well, here is the deal. Doing the RMS last night look into the crankcase and back near the 5 & 6 cylinder bores is something that looks like coolant... but I figure it is 1am and my eyes are playing tricks on me in the early morn... this afternoon I am changing out the oil pick up gasket... and I drop a piece of the ol' gasket into the crankcase... so I elect to turn her over and let it drop out... over it goes and down comes some oil, no gasket bit, and coolant.
Coolant?! WTF?!
Now, this motor ONLY ran rich before it came out of the car... no white smoke. The only guess that I have on how this got into the crankcase is via the front cover... How so you ask?
Well, I only drained 1/2 of the block (by accident) so when I popped the cover she must have dripped a bit of coolant into the now exposed pan. And after she got flipped for the RMS, the coolant must have made its way around inside.
BUT. This doesn't seem totally accurate since I HAD drained the pan before flipping her, twice. Each time I got oil. No, coolant. Or so I think.
Also, there is a slight leak at the back of the lower manifold, looks to be oil, caused by its evening on its top.
Is it possible that this coolant leaking is a bad manifold gasket or...?
Some thoughts on this please... because I am going to put the pan back on, flush the system with oil (quick oil change) and assume all is well.
Thanks,
Coolant?! WTF?!
Thanks,
