Coolant temp sensor
Sevy14
Anyone know the size of thread of the coolant temperature sensor on the passenger side of the thermostat? Also can anyone recommend a T fitting for running an oil pressure with the stock pressure sensor?
Can’t help ya with the size or pitch of the temp sensor.
HOWEVER, if ya go to The Depot or Lowe’s they should have the fittings ya need. For me, I used a tee capped one end & put the oil pressure sending unit on the other.
The temp sensor to the left of the thermostat housing is 3/8" mpt, if your still asking.
Apologies for previous misinformation.
Thought you inquired about oil pressure .
3/8 npt like every said
