Cooling Problems
  • Thread starter Thread starter BuickNut
  • Start date Start date
B
BuickNut
Guest
I have just recently had cooling problems, specifically fan not running. I have replaced the 3 relays with no luck. I have jumped the fan to see if it was the fan, it runs. I turn on the a/c and the fan does not come on. I have no check engine light on. Coolant sensor is next on my list. Does anyone have any idea?
Thanks for the help
Joe J Frede
SalvageV6 is who you need to talk to. He's one of the local electrical Gurus here that can help direct you to your problem.
HTH
Jim
I looked at the fuse block layout and I can not find a fuse for the fan.:confused:
There is a fan relay some place also could be bad.
Or the resistor at the fan could be bad also.
So. I would expect the wire or connector. checkout
www.casperselectronics.com
He has just about everything electrical for our cars.
Found It
It was the low speed side of the reastat on the fan. The wire was broken and it was not visible from the top.
Thanks all
Joe J Frede
