G
gm2bad
Guest
Need help with my fast system on a 94 Ford TFI setup.Something is wrong with the way its setup.When I install the wires as B to pip,A to spout,D to ground,Neg to points,12volt to start and run I get nothing,no spark and no rpm sig.But if I install B to where you want A it fires,runs,gets rpm sig but no spark advance.By the way Mike told me to switch them around.That is the only way it will run no other connections make any difference,connected not connected,as long as B is to A and its getting 12volts and ground at D with neg to Msd6AL white.But it just stays at 10 degrees.I have tried all other possible connections.Anything you can help me with.Thanks Gary.![Confused :confused: :confused:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
