Aug 5, 2012 #1 K Kurt04 Member Joined Nov 3, 2007 Messages 86 Press the button, nothing happens. As far as I can tell everything is there. Where should I start?
Aug 5, 2012 #2 S SIXBANGR mean old man Joined May 25, 2001 Messages 2,446 Kurt04 said: Press the button, nothing happens. As far as I can tell everything is there. Where should I start? Click to expand... switch under the brake pedal, may need ajustment.Try pulling the pedal up with your foot when you push the button. Also be sure you have the cruise in the on position .
Aug 6, 2012 #3 G GN owner Member Joined May 25, 2001 Messages 690 Go here to troubleshoot your problem: http://www.vortexbuicks-etc.com/cruise_control_trouble_shooting.htm
