Dam Electric cooling fan vibrating !
Mrneg9
Get Some !
Removed my electric fan the other day to install external transmission cooler. Put it all back together and now when the electric fan turns on it vibrates the entire car. Is there a way to balance it or will I have to replace it. Its always some thing.
I know of someone else who had the same deal. Turn out that the fan shaft was bent. Just a little. And yes these cars can and will be evil
How did you bend a steel fan shaft just by removing the fan assy and putting it back?
When I removed the fan I had noticed that one of the three screws that hold the fan blade on was missing. I drilled/ removed the broken screw and replaced with a new one. All I can guess is it bent while drilling.
