Damaged fuel lines from the frame to the fuel rail
TURBOTIMMER
Really looking for the 2 short metal lines from the frame to the rubber hoses for both the feed and return. I need the fittings that thread on the factory fuel lines on the frame.
I have all my stock
lines brake and gas in good shape if you need?
I'm really just looking for the short ends of the fuel lines that go from the frame up to the fuel rail. Basically from the frame to the rubber.
I could have used all the lines you're talking about a year ago when I replaced mine with new pieces from inline tube.
You can buy the feed line ends 3/8" from Dorman I have not seen the return line end. My roller I got it was damaged. It can be cut off and you can flare on a NPT fitting and put a barb on it. It will work fine the return line is only holding 10lbs of fuel pressure.
The return line is a unicorn. For some reason GM decided to reinvent the wheel so they could run a smaller orifice than just using a $.20 normal fitting.
I went round and round with this when I was going to make some SS braided lines for my car. That fitting just doesn't exist unless you have a lathe.
Shy of that the only way that's half way garage friendly is to harvest the fitting from a stock return line.
