Dayco Serpentine belt, anyone using it ?
transampacecar
My original serptine belt is badly cracked. I did a search here and see that several belts are used for the no longer available GM belt.
If I understand correctly the closer to 63 inches would be best ??
I purchased so far (And have not tried any yet) the following
1. Autozone Kelly Springfield 636k6 which is suppose to be 63.5
2. Napa 060623 which is suppose to be 62 7/8
3. Napa 060630 which is suppose to be 63 5/8
4. And lastly, a Dayco 630K6 which is suppose to be 63 I had the guy at use a measuring device and it did measure 63 inches.
Is anyone using the Dayco belt or are one of the other 3 above fit better ?
Did you look in the TTA FAQ list for the belts boardmembers have used? :) Might save you some time and aggrevation ;)
Yes, I did check the list. But it seemed that the Dayco 630K might be closer to original compared to the other belts listed. My question was just wanted to know how many were using the Dayco and if it worked for them. I did see from that list there was only one person.
Take it all with a grain of salt, I have the 63 1/2 inch kelley belt and it fits great, but you will never know untill you try it on Your car. I get good clearance but have heard of some people needing a shorter belt so there is some variances in these cars.
