Dead @ track - Code 41
Lynn D. Brown
Made 1 good run, died out and backfired on 2nd, had to be towed on 3rd and then wouldn't start. Coded a 41 - cam sensor system malfunction. So, what do ya figure, bad cam sensor ?
Do you have spark? If not my guess is you sheared the roll pin on the cam sensor. I'm going through the same thing right now. Also check timing chain and sprockets. Mine were still stock and all the teeth on the cam sprocket were laying in my oil pan.
