I have a SMC alky kit and it seems like that whenever I am running the car hard with the alky on, I always get a o2 sensor trouble code. I don't have a sophisticated scan tool so I can't get any readings. Will denatured alcohol hurt the O2 sensor? Also maybe I don't have the alcohol tuned right. I keep the pump speed in the middle and set the alcohol to come on at about 10 lbs of boost. I am running a stock turbo, intercooler, Reds 93 chip, etc. Have a 2800 stall. The best pump gas I can find is 90 octane, so I usually run that with some 104 octane booster.
Well since I have already written a short novel, I'll ask another question. I know that some of you run other alcohols (xylene) rather than denatured. What is the pros and cons of these other types
Help
Jonathan
PS
Also where is the ECM fuse. Is it at the top right corner of the fuse box. Is a 10 amp fuse?
Help
Jonathan
PS
