- May 28, 2001
Have a new, [1400 mi], Denso, [Supra] pump that is spitting fuel out of the check valve that's mounted on the top. I've checked the spring, and find the check ball is free, and the spring is not broken.
I was draining the tank, and heard this splashing sound. I lifted the hanger, and saw the fuel splashing out of the check.
I think this valve is a relief, correct? I'm wondering if I just lock it down what will happen??
[It shouldn't be opening as there's no back psi on the system.] JB WELD time!
NE1 had/seen such an issue?
