Originally posted by j13smiley
can some one explain to this turbo newbie where this is located and why you would want to adjust it? isn't that the "release valve" for the air?
Yep! The waste gate actuator is under the turbo. As you are looking at the car from the front, under the turbo you will see an actuator with a rod coming out of it going to the left where it is attached to the wastegate lever. This assembly opens and closes the wastegate. If there are threads on the rod it is adjustable. If you want to stay with stock boost there is no need to adjust it. If you want to raise the boost, then you need to adjust it.
