SignUp Now!So with the MAF PRO does it require a wide band o2? If so where did you find the set up for it? I am considering going with the pro to eliminate my stock (useless) maf sensor but just trying to know what all componets I will also need to go with it. I know I will need a different type of map sensor by the looks of it. Also does full throttle speed burn a custom chip for you as well with the order of the maf pro? Im just looking for a grand total cost wise and what all is needed from start to finish to try to get my car set up properly.
